loiner1965
- Sep 28, 2012
- 77
Right gentlemen Checked ignition coil and I get readings from the live to an earth point Also readings when I connect between both ht leads Checked the primary coil inside the flywheel which also gives me readings I will post readings if anyone wants them The points have been re set but were heavily pitted so the condenser must be on its way out I fitted new plugs and gapped them smaller as suggested but still no spark If I connect the meter between plug leads and pull on the recoil starter I do get a reading so electricity is being produced Any help much welcomed
