I have an old B100 that is not pumping water. I replaced the water pump impeller and gaskets. The old impeller was in pieces and I found most of them. I put it back together (twice) and still nothing comes out of the pee hole.
Is there a good way to check the engine for pieces of impeller? I would like to backflush it from a spot that allows me to do the least disassembly possible, because I am not a pro. We checked the thermostat area, but that's where I quit for the day.
Also, is there an easy way to confirm that I did the impeller change correctly?
Thanks for the help!
Scott
Scott
