Has anyone experienced acceleration issues when the throttle is opened quickly. The carbs have been completely done. Float height set and all jets clean. The motor has been run-up in test tank and the lync and sync was done with the vacuumate hooked up to the motor. The idle speed is correct and the mixture screws are set to spec. Have been working on two honda outboards. One is a 1997 45hp three cylinder carbureted and the other is a 2003 75hp four cylinder carbureted. Both have the same issue. Will accelerate slowly and may hesitate but when the throttle is snapped they will stall. The accelerator pump is also set to spec. Will order new check valves and see if it improves.
Any info would be great.
