Hi all, I'll start from the beginning so it's easier to getb the picture;
I took my Haines out on a sea trial as I have sold it however I let the purchaser drive the boat back to shore,
when we were close to shore I told him to tilt the motor and turn it off so we drifted onto the shore, I put the boat on
the trailer and went to drop the motor down onto the support arms and the motor wouldn't come back down, it was jammed.
So I waited until I got back home and several short goes didn't make any difference, eventually I held the tilt down switch for
longer than normal [ 5 to 6 seconds ] and away it went, up and down like normal, so I figured that he must have held it in the up
position for too long and over extended it [ jammed it ] .
So after a few more goes to make sure it was okay, I over extended it myself and held the switch on for longer than normal and after
a delay down it would go again, this has not happened to me previously so is it a case of the new owner causing the issue or do I have an issue??
Also I went to run my motor to flush it out and my main battery was dead as far as starting the motor went? It is only a couple of months old and
the little sight glass was red' which means 'contact your battery dealer' so could the tilt trim issue of trying to free it up a bit dropped enough charge out of the battery to affect the starting capabilities? [ note battery is only kept trickle charged via a tiny solar panel 200mm x 150mm.
What do you think?
Thanks in advance for any replies
What do you think?
