honda 90 specs
Bill B
I'm looking for torque specs and sequences for headbolts and intake manifold bolts for my 1996 honda 90 hp.
hondon
Re: honda 90 specs
I will try to remember to send those specs to you tomorrow.Do not try to torque this unit together without those specs or you will concievablly pull the threads right out of the block"Do'nt ask me how I know that"But these are torque to yield bolts which means they are torqued to a certain value then turned another amount of degrees.Be very carefull here.Back off all valve adjusters,set TDC before you remove the head and keep in mind that head will not want to stay at TDC while sitting on the bench.
