100hrs on engs. At above 5000 rpm it sputters and bogs down, usually after 1 1/2 hrs running. 4500 rpm all OK.Clean tank ,clean lines ,new filter (OMC 3214),new gas (unleaded reg), purged all air from lines,new anti-siphon valve to tank.Replaced fuel filter in eng.( before fuel pump).The other eng on port side,not as bad but does the same now and then, Mechanics on Kauai new to this eng. no clue??? I suspect a relay for the EFI system, maybe, re: fuel pressure at high RPM ??? Any help, much appreciated.
