Re: Honda 9.9 Impellar Replace, How To Do???
Step one: put it in reverse
Step two: about 1/2 down the leg you will see a threaded shaft w/a small regular size nut (10MM) and a larger one about 3/4" long also 10mm. Back off the small jam nut just enough to allow the long nut to unthread and disconnect the shaft. The rest will come out when you drop the lower end.
Step three: Take the four 10/12mm bolts loose, leave one attached to hold the lower end until you are ready to handle it, then take the 4th bolt out.
step four: take the 4 small bolts loose that holds the pump housing in place and remove the housing. You will need to replace the gasket. Look for the key way and make sure you get it back in place. Look at the old impeller and reinstall the new one bent/curved in the same direction, reassemble, you are done.
