Honda 9.9 Alternator?
carpenterken
My honda 9.9 (2002 model) has a plug next to the handle that says 12 volts 6 amps? I'm guessing this is a plug to an alternator? If so can I just get a plug to fit it and hook it up to keep my battery charged when using it as a kicker?
pwiseman
Re: Honda 9.9 Alternator?
You should not need to do that. I believe the alternator will charge your starting battery with the main cables that go to the battery. Sounds like this is a plug to run other electronics from.
carpenterken
My 9.9 dose not have electric start, or any wires going to it.
pwiseman
Well that explains it then. What you are looking at is a 12V plug that you can run a fair bit of things with. 6 amps is enough to keep a battery charged as long as you are not running something like a trolling motor.
tashasdaddy
it's a feature they put on to charge batteries, had a sail boat that we used the honda, to keep the batteries up, when motoring.
