I just bought a Honda 9.9 2003 model that had never been used. I started it up (fired on first pull) after changing the oil and running clean gas throught the fuel system a few times. I hooked up a dual sided flushing system to the water intake ports. I could't see any telltale water stream indicateing that the cooliong system was working so shut off the motor. I then purchased a Honda flushing adapter that screws in a port under the engine cowl. I turned the water on and the cooling water streams were all working great - thought there may have been a temporary blockage internally. I then replaced the dual flushing device over the water intake ports, turned on the water supply and restarted the engine - still no water stream indicating proper water cooling.<br /><br />Can anyone give me some advice on what I should do next? Thanks in advance.
