I've put a meter on the DC receptacle, and see less than a volt while the engine is running and in neutral. I replaced the fuse (5amp), and still do not see a charge.<br /><br />Looking at the schematic, I see two blue wires coming off the flywheel, and go to the rectifier. Just wondering if there is a place I can check voltage to determine if my rectifier or something else has died. I'm assuming it would charge in neutral? I can't put it in gear (knock the flush attachment off with the prop spinning)..<br /><br />If I can test voltage before the rectifier (AC), and right after it (DC), what voltages should I expect? I'm assuming 12vdc after the rectifier, but not sure what kind of VAC gets fed into it.<br /><br />Thanks in advance,<br />JW
