Last time I posted a question on this forum the responses were very helpful so thanks to anyone who can help in advance!
I have a 2005 Honda BF8D which is only used in salt water. Although there are no problems with cooling water circulation (yet), the guy who just replaced the impeller told me that there is quite a lot of salt build up in the leg. I'm quite surprised about this because I've only ever seen salt crystals accumulate in the passages in the engine block before and didn't think cooler parts would be affected. I'm also very careful to flush the motor with fresh water after every use - I run in in an 80 litre barrel for about 10 minutes and then stop it by disconnecting the fuel to make sure the carb is drained. I don't know know what the previous owner did with it for the first 4 years though. Anyway, the maintenance guy said that I should use flush muffs instead of a barrel because all I'll do is recirculate salty water around in the barrel. So here are my alternatives for flushing the motor:
1. Carry on using a barrel - I thought this would be best because it gives the thermostat a chance open
2. Use flush muffs (I'm concerned that if I get a bad seal and starve the water pump I'll create plenty more problems)
3. Use the built-in flush port on the thermostat housing
All these are possible but can anyone advise which is likely to be the most effective? Also, should I be using 'Salt Terminator' every time I flush the motor or would I be wasting money on 'snake oil'? Finally, is it worth a pre-season flush with Rydlyme to clear out any deposits while I know I can get stuff circulated through the motor?
Lots of questions but I'd be grateful for any advice as I really want to avoid a blocked engine!
Thanks.
Thanks.
