imported_Seachaser
- Jul 9, 2006
- 1
Need help with a hard start issue with my 99 Honda 8hp. It may take upto 20 to 30 pulls to start the motor when cold. When warm she starts with one pull. I have replaced plugs and it help little. It sat for more than 5 years and when I got it I replaced all fluids and flushed gas . I took into shop and they said the carb has no choke adjustments but did a trick and it still takes too many pulls... any suggestions?
Also, what should the compression be for this model? I tested and it measured 95 lbs in both holes.. Is that to spec.?
The motor runs good once it starts and will run all day... Since the shop worked on the carb the plugs will foul after a couple of days of trolling...
