Honda 8.5 impeller replacement
PeterHornby
I am dismantling a 1980 Honda 8.5 HP lower unit to replace the upper bearing and seal and am working without a manual (out of stock!). I would like to know how to separate the lower part of the drive shaft from the upper part in order to replace the water pump impeller.
steelespike
Re: Honda 8.5 impeller replacement
Have you tried the library or NAPA?<br /> NAPA lists a Clymer manual for 2 to 150 hp.<br />Part number 18-0097.I would strongly suggest<br />you work from a manual.<br /> Id be glad to get you started but havent a clue about your motor.
