Honda 75 ---7.5--
dons
We just purchased a sail boat with a honda mtr. Aprox 1985????manual start with alternator charger<br />Questions<br /> 1 Where to look for model and serial numbers<br /> 2 What recomendation re flushing as it is used in salt water Thanks for your help Don
hondon
Re: Honda 75 ---7.5--
Your frame serial # will be on a black and white sheet metal tag on the part of the engine that clamps onto the boat.These tags can disappear and often do.There is also an engine serial number stamped right into the cranckcase of your engine.Look carefully at the front of your engine,to the left of the carb and above all the throttle and shift linkage,you will see a long box that after wipeing some oil off you will see the engine # stamped into the block.Hope this helps.
