I just bought a used 7.5 hp which ran rough and did not want to idle down. Cleaning the plugs didn't help, but cleaning the needle valve port on the carb did the trick. It smoothed out and would then idle down. I was all set, I thought!
I put the cover back on and from then on I've not been able to get it to restart. It won't so much as cough.
It became obvious early on that it wasn't a fuel problem, but an electrical problem. I first checked all the wiring to be sure I hadn't accidentally pulled something apart. Everything is intact and connected as it should be.
I then checked to see if I was getting spark...Nothing...Zilch.
Anyone have an idea as to whether this is a coil problem, a CDI unit problem, or something else?
Thanks for any help you can give!
