Re: Honda 5hp
This is my first post here. I have been posting for years on other boards, but just found this one.
My Honda 5hp has recently died from electrolysis/corrosion & lots of hours. This motor does not have the rubber hub like other motors. When the shear pin breaks, it is as if the motor is in neutral.
BTW, when your motor is a few years old, pull the head & remove the salt buildup if used in salt water. You might be surprised how bad it looks inside even if the outside of the motor looks brand new. Also, always check for water in the oil(milky). If overworked, this motor can blow the lower main seal & let water in. It won't take long to cause serious damage.
I need more hp & will be replacing with a 9.8 Tohatsu 4-stroke. Anyone want to share positives & negatives about that engine? I could go on & on about the 5hp Honda goods & bads(it even says BADS on the motor. That should have been my clue. Thanks everyone!
