Honda 50hp drain/fill gaskets
psteurer
I've got a 2008 Honda 50. Was wondering what gaskets to use on the drain/fill plugs that hold the lower unit gear oil. The Honda Marine dealer I bought the motor from said to always replaced them when one changes the lower unit oil. I went to a Honda Marine dealer that was closer to me in order to buy some. He said he never replaced them and did not have any in stock. I understand there two types of gaskets: one type is a rubber o-ring and the other is a nylon type washer. Does any one know whether the Honda OEM part is a nylon washer or a rubber gasket. Also, any recommendation on which one to use? Thanks
robert graham
Re: Honda 50hp drain/fill gaskets
My motor is a 1999 and still has the original red "fiber" type washer/gaskets on the drain/fill plugs. They still look new so I keep using them but I do have a pair of new ones to put on when the old ones look warn. A lot of folks recommend new gaskets every year just to be safe. Good Luck!
scallop
go to boats.net and get them there and you can look up your own parts.
walt-oxie1
I just buy the nylon washers they sell at lowes (usually in the bins in the hardware section). I use them for gaskets on all kinds of bolts/plugs and have not had one leak yet. Just take your plug with you and match it up. You usually get 4 for less than $2.
