Honda 45 four stroke
farley
I had my boat vandalized last week and they pulled my wires apart from inside my motor compartment pulling the pins out of the plug and breaking wires.The plug is a 14 pin.I looked at all eletrical supplies stores in my area and not one has seen this plug before.If any one can help i sure would appreciate it.A new harness from the controller is $274.. Canadian
steelespike
Re: Honda 45 four stroke
If it is under the hood the electronics store should be able to supply any number of different connectors with the pins and tools to make up new connectors.I would guess around 30 dollars.You might even split it up to 2 or 3 connectors.
Skinnywater
Or you might be able to match a connector just like that one on a Honda car at your local auto wreckers.
While many wreckers will hesitate to butcher a harness on a late model, many will allow you to cut away at an older one.
