Re: honda 40 hp 4 strk prop size?
Without knowing WOT RPM on your current setup, picking another prop is a guessing game and it may be that a prop change is not even necessary. For example, if WOT RPM is 6000 RPM for your engine and with the current setup its only turning 5000, you are lugging the engine and could use a prop with less pitch to bring the RPM up. Conversely, if your current RPM is over 6000 RPM you are over-reving and would want to increase pitch to bring RPM back into the proper range. If your current prop provides 5800 - 6000 RPM with the load you normally carrry, no prop change is necessary.
