BEARCATJER
- May 24, 2008
- 12
I have a 2001 18 ft Starcraft pontoon with a 2001 Honda 40HP 4stroke motor. I bought this rig used about 5 years ago and during that time we havent used the boat as often as we expected we would.As a result I have had to have it "tuned up" several times and every time i do it seems that it doesnt last very long before it starts running ragged and stalling in idle gear.Unfortunately i didnt buy this boat from the marina on the lake where i live so the nearest Honda dealer is 30 miles away.I dont have a trailer because it stays in the water at my dock do getting it to a dealer is an expensive proposition. Four months ago i had the motor extensively tuned up to the tune of $500 by a local crackerjack mechanic.Since that time the motor has purred like a kitten and runs very well. This past weekend we got on the boat to take a cruise...hadnt used it for about 5 weeks. Motor started fine but after warming it up and putting it in idle ..it stalled. It would easily start using the choke everytime but would run ragged for about 15-20 seconds and then stall when i put it in idle. I dont use gas with ethanol and I do use the stabilizer my boat dealer recommended. Anyway, i got the boat in gear and took it out on the
big lake and ran it for about an hour.It ran beautifully, but when i stopped it out on the lake and put it in idle,it stalled just like it had at the dock.
I cant figure out why it runs so well but wont idle! Im not very mechanical but I'm not totally stupid so I figured that maybe if i could adjust the idle screw it must have somewhere to a higher rpm setting it might do the job.As it is when i put it in idle it runs at about 800RPM for a few seconds and then stalls.
I dont have a service manual for this motor.I took the bonnet off of the motor but couldnt figure out where the idle screw might be. Then i got the bright idea of asking the experts on this forum for some help or suggestions to solve this aggravating problem.
Any helpful advice would really be appreciated. This motor doesnt have more than 100 hours on it in 10 years.My ace mechanic says it is in excellent condition...compresion etc.
Thanks for your help.
