firechannel
- Jul 11, 2004
- 2
I have a 2 hp Honda that was stored upright over the winter. I laid it on its side throttle up as recommended and crankcase oil started leaking from the carburator apparently and some out of the air intake plastic thing. The spark plug was also oily. After draining the carburator and cleaning things up, the engine started and ran normally but it still leaks oil when laid on its side. How is oil getting into the carburator area? I can't transport the engine on its side without causing an oil slick when I put the boat in the water as the oil drips down the shaft and gets all over everything. This engine is about three or four years old and has probably less than twenty hours on it.
