Honda 2hp Bf2 Lower End Removal Problem
namor
I've got a mid 90's HONDA 2HP model BF2 and am trying to remove the lower end but can't do it. The 2 bolts holding the lower end to the vertical shaft were removed but the lower end won't budge. Is there a trick to this?
Anyone whose been in the same situation with a remedy and a reply would be greatly appreciated.
Thanks
Gus
Toronto Ontario Canada
namor
Re: Honda 2hp Bf2 Lower End Removal Problem
do you have the manual?
Yes i do;its the owner's manual and it mentions nothing about lower end removal. Someone told me of a website called I think stemtostern.com which shows schematic blow-ups of Honda engines. I'll check it out
zzzzz
you can also pull up parts diagrams at boats.net :cool:
p15camborne
I have the shop manual. Just shows one bolt on the front side going down, and one bolt on the rear side going up through the cavitation plate to hold the gearcase to the extension case. Of course, the shaft is externally splined into the gearcase and internally splined on to the crankshaft. Also there's the water tube which slips into a rubber grommet at the water pump. Torque to tighten the two bolts is 5.8 to 8.7 ft-lb. Maybe the splines have been connected so long that some force must be applied?
The impeller slips over a pin passing through the shaft. Slid the impeller up the shaft. Slip the pin out of the shaft, the slide the impeller down off the shaft. After installing the new impeller on the shaft, the impeller must be seated into the pump liner while rotating the shaft clockwise looking from above. The impeller vanes must bend away, arch back, from the direction of rotation (clockwise from above).
My engine is a 1997. It was my kicker on a sailboat. Now I use it as my backup to my F9.9 Yamaha on my aluminum boat. So it has very low hours. Original impeller still works fine. So I've never tried replacing it. Only trouble I've had with the motor is the carburetor requiring cleaning.
Good luck.
namor
Good luck.
Thanks p15camborne for the research,good job,it's bung up somewhere,when I get a chance i'll soak those two bolt holes with wD40 or liquid wrench and use a rubber mallet to pry the lower end off
gus
paintitup12
Is it rust? Rust can sometimes be a big problem around saltwater around saltwater areas
treflip
I have the same prob. and shop manual. I've been beating on the lower end and spraying PB blaster all over it. I was wondering if u ever got urs off and if so HOW!? :) Txs
kayakn
what color is the motor?
