Honda 2008 model 115hp dies
AliB
One of my motors keeps stalling when in idle, after which it struggles to start and when it does start and does not die when put in gear only runs at low rpms, I have serviced the motor and cleaned the fuel pump, please any advise would be appreciated, I am in a remote area hence access to authorized honda dealer is near impossible. thanks in advance.
hondam
You are probably right with it being fuel related have you put a fuel pressure gauge on it? Did you replace the high pressure filter? I would also check the IAC valve screen.
AliB
Thanks Hondam, no i haven't put a pressure guage on it, i will do that soonest.
