rswearingen
- Jul 14, 2015
- 1
hey guys I am new to forum / rocko is the name / got a 225hp 2003 not firing on one cyl / test that have been done are , has spark / has 200psi comp.,fuel injector is pulsing and spraying fuel / replaced with new inj.,continuity test ran on coil cap wire to ecm test ok ,/coil was swaped out with new one / so my question is can a ecm problem cause one cylinder not to fireoff / if so how does it do it and how do you test to see if ecm is the problem ? thanks
