Oil leaking from weep holes lower leg .. After checking the dip stick it appears the engine oil level is down and that may be the cause. What could be the problem.....how could the engine block be leaking the oil?
All it takes is a bad output shaft seal - that is the lower crankshaft seal as well. Are the plugs oily? Possible to pump oil out the exhaust into the extension case as well.
