honda 200 hp 2006
captgarysr
# 4 and#5 cyl wont fire . good compression ,good spark, fuel injectors working just wont fire ,changed ecu , still no fire .... any thoughts???
MattFL
Master Chief Petty Officer
Check the spark and fuel injectors on those cylinders while it's running. You can get a spark gap tester where you can see the spark, make sure you see spark when it's running. Put a stethoscope on the injectors and make sure you hear the operating when the engine is running.
