Honda 15 hp servicing info
mistyb33
Just purchased 1991 Honda 15 hp 4 stroke with electric start. Require any relevant servicing info or hints please as I intend to do this myself.
gss036
Re: Honda 15 hp servicing info
Just an occasional oil change and lower unit oil. There is an onboard fuel filter, easy to see through,remove and back flush if need or replace.<br />They have been known to make oil (gas bypassing the rings)so you need to watch that, it is usually cured with a hotter thermostat. If you run in saltwater, make sure you have a zinc on it as they will tend to have corrision problems in the mid section. Take care of it and it will take care of you.
