Re: honda 130 stalls
What year?<br />Do you have a Racor filter?<br />Is the primer bulb flat, can you get a firm bulb when primed?<br />Is the fuel filter clogged, has it been changed?<br />Is the VST clean - is the needle sticking closed?<br />Do you hear the sound of the electric fuel pump pressurizing the system when the key switch is turn to the 'on' position (not start)?<br />These are all fuel related - I'm sure someone else here can add ideas on fuel or non-fuel related problems.
