This is what happend. I just bought a boat with twin Honda outboards. They are BF 130A 4 strokes. Both are 98' models. The problem is that the main engine realy will not work. The guy who just sold me the boat odered the relay for the motor 2 times, and both do not work. I have tested the good/old relay on both engines and both engines work. When I put the new/ordered relay on neither engine works. The number on the relay is the same one as in the parts manual, but there are some smaller numbers that are diferent. Both have the same part manual number written in big letters 38580 ZW5 004. Here is where they look diferent. The GOOD ONE has written MAIN RELAY ASSY-DC-12 v -8-H-21 IMANSEN. The BAD ONE has written >PBT-GF30 <EXT DC 12 v >EP< 4 D 23 IMANSON. I called the Honda dealer in Hawaii and they said that the relay is the correct one and there should be no problems with the small lettering. Does anyone know how I can get this thing to work correctly. Is there some special trick to getting new relays to work correctly on your engines? Is there a way to test to see if the new relays are actually not defunct? Any advice would be much appreciated. I am out in Micronesia so getting parts and help is a bit tough. Thanks, Chris
