Greetings, gruppe, new member here. I have an Eastern 22 with '01 Honda 130. It has the standard cable steering setup (Teleflex, I think) not hydraulic. The motor runs great with about 60 hours on it, and has no problems except this one: <br /><br />I had the motor serviced and winterized by a Honda dealer last fall. It started and ran fine this spring, except that the steering started getting stiff. I should note that I use the boat intermittently during the boating season in the Northeast, and the problem is most noticable when the boat has been sitting a while. <br /><br />It appears to me that the steering actuating rod (the part attached to the cable coming from the wheel, and then attached to the motor. Slides side to side when steering) is binding up. This part goes through a bushing or seal and does get a bit stained when sitting (salt water environment), but not pitted. I have lubricated and polished this rod and the bushing/seal, which seems to help, and have given all the Zerk fittings a shot of grease. But the steering is still much stiffer than when the boat/moter were new.<br /><br />Any ideas? TIA<br /><br />Jon
