Re: Honda 130 compression for 2003
Those compression numbers can vary a great deal from guage to guage.With that said numbers around 200 psi on a quality guage are normal and any cylinder that falls below 17% of the others is cause for concern.After that a leakdown test is advised to find the source of the leakage and the repair could be as simple as a valve adjustment.Honda dropped that 130 recently only because they introduced the 135/150 line.They still make it,s 115 little sister.Great engines this vintage but had a few issues in the introductionary years.You are well beyond those.
