craneman72
- Apr 1, 2004
- 16
just came up with these yesterday and installed them, worked great,<br />i went to the local hardware and bought 2-3ft sections of galvanized pipe, threaded on each end,<br />2-elbows,1 male end, 1 female end, 2 end caps and 2 of the round sockets for gas pipe, these are round with 4 holes in and a female end that you normally use to screw into a ceiling joist or a wall then screw the pipe in to.<br />i used 2 of the holes in the round socket and a flat bar and mounted to the side of the trailer, with 2 bolts, 1 above and 1 below the square channel,placed the flat bar over the bolts with a couple of lock washers then tightened up, <br />next i installed the elbow into the round socket(make sure you get this as tight as possible the first time)then screw in the 3ft section of pipe, <br />i bought a section of pvc pipe that fits perfectly over the pipe but still spins, cut that to length and slid over the pipe and installed the end cap.<br />pvc acts as a roller and should not harm the boat and instead of paying 65 to 75 for guide ons, the whole mess only cost me about 15.00<br /><br />i will try to post pics if i can get the wofes digital camera<br /><br />
