HOLLEY CARBURETOR
magicbandit
Does any one know where the model number is put on holley marine carburetors?<br />I need a renew kit and can't find the stupid model number<br /><br />Thanks,<br />Mike
D
DJ
Guest
Re: HOLLEY CARBURETOR
Jazzy,<br /><br />Usually there is a tag attached to the carb.
Gene70
At the front top half of the carburetor there are numbers on the flat surface. They are printed in the aluminum. The word list will be there and the number will be after that. If you have corrosion there take a steel brush and brush some of it off so you can see it.
magster65
Stamped on the baseplate I think. Take it in with you and match it up to be sure though. I don't think Holley made too many different marine carbs.
