Holley carb manual....
JustJason
Figured i'd ask here.... Anybody got one? I need one for a 2 barrel.... More specifically it's on a 1990 OMC 4.3..... Don.... rodbolt..... Bondo??? :)
I won't care if its stuck in the middle of a VP manual... but i've went through my Merc manuals (which if anyone needs pm me) and can't come up with one.
Thanks all
Jason
Don S
Re: Holley carb manual....
What's the "List" number on the carb? It's on the airhorn.
JustJason
I knew i needed some sort of tag number..... I won't get back to the boat until monday/tuesday so I may have to let this post sit until then. Unless I can get the customer to get the # for me or figure out another way to ID it.
Thanks Don.
JustJason
ps. i'm 99% that its a 2300 series carb... thanks again.
JustJason
rebuild instructions, float heights, exploded diagrams, really just any kind of nomenclature as I have none for holley.
Have to do a carb job, and haven't been through a holley in 3 or 4 years... wanted to brush up thats all. I know there fairly simple using the metering block vs jets with needlejets, but it's just been awhile.
danond
The instructions that come with the carb pretty much give you what you need to know when it comes to adjustments for the 3250. Even includes a ruler for setting the float.
If you're even remotely mechanically inclined, what comes with the kit is plenty to git'er done!
