Hole in water pump system/lower unit
bprender
So I just bought a used engine (a y2000 Honda BF8A), and it was having water pump problems. I took apart the lower unit and replaced the impeller and gaskets. When I was doing this, the metal edge that the gaskets seal broke away a tiny bit. I don't know what any of these places are called, so I'll describe where it is. <br /><br />The water comes in through an intake screen and flows through the gaskets and into an area underneath the gaskets, where a rubber donut separtes the oil of the lower unit from the pump system. It is this edge, just below where the gaskets seal and above the donut, that broke away a bit (about the size of small fish scale). <br /><br />My question is, what can I do to fix this problem. Do I need to take the lower unit to a repair place and get a weld on that, or does someone know any cheaper/better way of fixing it? Is there some metal compound that you can apply as a liquid, and then hardens? Can I reform the wall with some marine sealent from 3m? I was thinking that since it is in the wall at the primary/coldest part of the cooling system, I could just get away with plugging the hole with sealent. <br /><br />Any advice?<br /><br />Best - Bryan
Re: Hole in water pump system/lower unit
Hi Bryan<br />My honda B75 has the same fault. On mine, next to the impeller is a small aluminium housing held by two hex bolts. Water comes up from below into it... and goes out the same way!<br />I currently am running with some aluminium drink can which closes off the whole area (temporary repair, failed in use on the Caldon canal, ok, last summer LOL)I kept the holed housing to clamp the sheet material.<br />Does this sound like yours?<br />Nick
bprender
That drink can sounds pretty funny. Mine isnt in that aluminum thing though. Its in the actual steel of the lower unit that is part of the water pump system. Argh.
gss036
If you try some JD Weld and let it harden up and then sand down for a good fit, I think you could get away with as long as there is no real stress on the area.
hondon
I think I'm with you.We are talking about the driveshaft seal and the seal surface around it.Correct?There is nothing steel there however,so maybe I'm not with you .After rereading your post several times I'm still not sure what direction to send you .Give us a little more.
