Valv
- Jun 12, 2001
- 391
Hi, I have an interesting thing to post. I have 1989 30hp Mariner OB, motor was running fine (previous owner heard a bang and discovered a hole in the block), I purchased it convinced to rebuild. Just for fun I tried to patch. The hole is approx. 1/4" is in the lower end of cyl # 2 near motor mounts, and has a crack 2 " long from it.<br />I used some alluminum putty/epoxy and closed it so for the crack. Now motor runs fine, great compression, etc., and we use it continuosly on a 14' alluminum boat.<br />Question is: what can cause a "trauma" like that, and keep motor running without problems ? No rod or bearing noises, starts at first crank....Yes, I do ALWAYS carry a trolling motor just in case, and I DO know I'll have to rebuild, but I want to use it ans see how long it can go...<br /><br />Thanks.<br /><br />Val
