Profittakr
- Aug 24, 2009
- 38
I hit a sandbar at nearly full throttle. It was only deep enough for prop to hit as boat remained floating. I obviously got out ok and boat is running ok I think but I am just wondering if I should do anything or inspect anything to make sure all is ok. I don't think it got up to the water inlets and I don't think sand got in but who knows. No sand up near the thermostat. It polished the prop pretty good and I think the prop spun on the hub a bit (I had marked it when I installed the prop after water pump replacement) but I had no other prop related problems after that. Anything I need to do?
