Hit Sandbar, destroyed Prop... need advice
derekb95svt
Over the weekend I was haulin *** down the river (which by the way is lower than normal thanks to the drought) and hit a sandbar. No damage to anything other than it chewed the prop up real bad.
Anyways, I am looking for advice on getting a new prop. I have a 1989 ArrowGlass 23' cuddy with a Merc 5.7 Alpha1. Since it is used for cruising the river I need something that is durable and good on performance. Any suggestions?
Thanks in advance
PS I have no clue what the pitch means (I am a total newbie)
derekb95svt
Re: Hit Sandbar, destroyed Prop... need advice
Alright I pulled off the Prop and the numbers I got off it were J 14 X 20F if that helps at all
rndn
I'd go with an SS 4 blade, but realize nothing is going to take a direct hit like you did and not need some serious work although an SS is harder than aluminum.
toghog
stuff happens! oh well prop ain;t the end of the world.
14" is the diameter 20" is the amount of pitch. Providing that the boat hit it;s wide open trottle with that prop put the same size back on. wot is a manufacturers specs for their boats.
If you boat in a place where this happens all the time I would buy props that are less expensive. If it is not too beat up they can be repaired.
welded and reshaped. good luck ps; check out e bay
jpg1130
Nothing against SS, but for the price of one SS, you can destroy 3 aluminums.
Just my $.02
eriediver
The problem with Stainless props is if you have a very hard prop strike you are more likely to damage the outdrive.
RobsTV
Just my $.02
Going from SS to Alum was one of the biggest mistakes I made.
And, it actually cost me more to go with aluminum.
Reason it was more is because the aluminum was a budget $125 "brand new" Michigan Wheel.
After performance dropped a ton, bought a used "like new" $75 SST II prop on ebay, and huge improvement.
If original poster had not specifically mentioned "sand", perhaps aluminum would be a better choice, but if it is possible hitting sand bottom, then a SS might not even notice. The SS does have a rubber hub to help reduce or eliminate damage of lower unit, so it's not as risky as it might seem.
jimmbo
The very day I had put a SS on one of my boats was the day I found a ridge of rocks. The boat was only going 22-23 mph when it hit. The damage to the gearcase was minimal, a slight twist to the skeg, no chunks just a twist. The prop had bent and torn blades. The prop shaft was also bent and needed replacement
