Hinge pin
vipersinu2
I tring to see if anyone has advice on why the hinge pins are threading in so far. The pins are going in so far their touching the bellow. Also the hinge pins are threaded in so far that the trim sensors can not set into the hinge pin. I do not see where the problem is. Has anyone seen this before?
vipersinu2
Are these susposed to be flush?
alldodge
There should be a fiber washer on each side between gimbal ring and bell housing
What year is the boat?
vipersinu2
Thank you for the message. I have a 2000 Mariah 302z. There are fiber washers. The fiber washers are in perfect condition, I went to Ace Hardware and purchased 5/8 stainless steel washer. I was able to use the stainless steel washers as a shim on both sides. Those washers filled the gap between the bell housing and the gimble ring. The hinge pins are now flush for the sensors to catch the hing pins.
alldodge
Thanks
was thinking Gen 2 and being a 2000 it is
The part is item 30 in LINK for use with trim sensors in addition to the fiber
Fun Times
Did or does your trim sending units have the grease zerk fittings?
Was there any previous work done of your knowledge to the ring, hinge pins, bellhousing area that had some changes to possibly wrong parts used or other parts forgotten.
The hinge pin itself (and ring #27 vs old #1) changed design as noted by item number 5 vs 28 plus you'd need the bushing #29 and the washer in question 30 with the new vs older setup..., https://www.mercruiserparts.com/bam/subassemblydetail/46516836/28171024
Anyway, though years ago now but your scenario dose sound familiar of knowing about that possibility have happening... Glad you found it and was able to remedy it.(y)
