Re: High Voltage
Unregulated systems (rectifier only) typically run quite high system voltage. This may in fact cause voltage sensitive electronics like GPS and locators to shut down. While the battery typically can handle these voltages, very long high speed runs may cause battery overcharging and subsequent loss of water. Therefore, its a good idea to monitor battery water level. If the high voltage is affecting electronics, Radio Shack and other electric stores can provide a voltage regulator to install in the power lead to each device.
