Hi, I have two engines 75 HP 2015 model, bushing 25 fit fiberglass boat and I noticed the outcome voltage is reached 15 to 15.5 v while both engines are working and the same if using one while trolling. On full speed the voltage reached 17.5 from both engines, so I checked the battery which is new (70 Amp) and changed the Regulator/Rectifier and still having the same issue (not sure if its an issue or normal for two stroke engines). also I changed the stator but the voltage remain the same. all wiring and connection are ok.
what else I should check and change? Is this normal! what is the normal voltage for this type of engine.
