Re: High Voltage reading
Does the manual tell how many amps can come out of the rectifier? On mine it says 7 - 9 amps. If the battery is fully charged when going high rpm then somewhere around the rectifier output would need to be used to drop the voltage down. I'm interested in the answer since I suspect that I have a similar situation with mine. Have a volt gauge ordered and then will be able to monitor the volts and see if something needs to be done, although I don't run the long durations that you are running, Just maybe 15 mins and then onto the kicker for some trolling. When running, my engine uses no current, the stators other windings make the charge for the spark. The trim motor must pull a fair amount of current, If you can determine what that is then try to match it with accessories, a good coffee maker should just about do it. Just kidding, don't know of a DC coffee maker available, but you could hook up a inverter and run some AC stuff. JH
