high pitched buzz from engine alarm
ocean goin
I have a 93 200hp Yamaha and if I turn on any switch with the engine on or off like for the bilges, lites, electronics etc. I can hear a high pitched buzz from the engine alarm, it's barely audibal but annoying as hell, it never did this before any ideas on what causes it and how to fix it. I can still hear it AAAHHHH.
Yepblaze
Re: high pitched buzz from engine alarm
A bad ground might cause that. Trace all grounds from the controls and guages area back to the motor, and battery. <br /><br />You might try making it sound off as you explain then take a piece of wire from the battery negative and probe the control head and any other suspected area. When the sound goes away you have found the ground.<br /><br />If that aint it......... you just stood on your head, double jointed, and acomplished nothing but a good workout.
Shamster
I would have to agree with Yepblaze. Either a poor ground or short of some sort in the wiring . Look over all your connections and wiring. I can only imagine being annoyed by the sound and your thinking the motor might be getting hot. :D
ocean goin
Thnx fellas I'll try that tomorrow eve. The buzzer dosen't sound off like it was overheating or out of oil it's a real faint buzz like a dog whistle, the old fingernail on the chalk board cringe. I can STILL hear it
