I have a 1989 Mercruiser for Cruiser 7.4 330HP that I am building this winter. It starts out with forged 30 over pistons Edelbrock rpm intake manifold and matching cam shaft, double roller timing chain. I swaped peanut heads and fitted it with GM large ovalport heads, roller rockers, and some more goddies here and there. However, I am not a millionaire and figured I could save for an exhaust over time. It has come to my attention that from the aggressive profile of the camshaft.... .570 lift at valve and 240 duration at .050 I might have a problem with reversion. Currently, the engine has stock exhaust manifolds with 4 inch elbows, and 4 inch through transome exhaust. Any technical help or advice on this situation would be greatly appreciated. Also, does anyone think that this was a good edging combination? Also, I forgot to mention the forged pistons are 10.5 to 1 comp.ratio. Thank you much!!!!
