1989 4.3L 262 Mercruiser V6 2 barel
SO I installed a new head on my engine, put everything back together. Took it our for a spin and my Oil Presure is 6opsi at idle and goes up to about 75 or 80 at 3000rpm. THis is much higher then the Manual#7 says it should be
THey specify no less then 4psi at idle and no more then 45 to 55 at 2000rpm
I put new plugs In it
Tested the compression at over 150psi on all pistons
Droped a can of Seaform in the oil
Yesterday a cuople of times the pressure at idle after planing would drop to 40psi and bounce around then go back to 60psi
My question is how worried should I be. do I let the Seaform do its bit for a while... DO I pull the engine out and rip apart the oil pump... Is it just some crap in there that will work itself out eventualy??
Is such a high oil pressure uncommon anybody else out there run the same engine and what is your oil PSI at ??
Thanks guys
Thanks guys
