High idle at 1900 RPM. Otherwise good
CaptainMak
Replaced all my bellows this winter. Pulled engine to replace oil pan gasket and rear main seal.
When I started her back up again, the idle RPM was around 1900. It was nice and smooth idling, no shaking, sputtering, racing, etc. Just stayed at 1900.
Went to check the throttle cable. Seemed okay. Took it off, boat still idling at 1900 RPM.
What gives ? IAC, TP Sensor ? Engine is a 2001 5.0 EFI Alpha...
CaptainMak
Re: High idle at 1900 RPM. Otherwise good
Could last season's fuel also be the problem ?
Volphin
I'd be searching for a vacuum leak and checking the timing.
alldodge
+1 with Volphin, may have pulled a vacuum line loose when winterizing. If not that pull the IAC and IAC muffler in the throttle body
CaptainMak
I was wondering if anyone can help me out with this IAC valve.
When you unplug it while motor is idling, do your RPM change ?
Because when I unplug mine, nothing happens to idle speed.
Just to make sure, here's the pic of it. It's on the LEFT with 4 wires.
Bt Doctur
disconnect the throttle cable first at the TPS
alldodge
I don't know of an IAC with a vacuum line, they have an electrical plug
Edit: the thing with the 4 wires coming out of it
CaptainMak
Not sure if it's a vacuum line, but I've seen some IAC VALVES with hose coming off it. If I take TPS connector off, engine starts shaking and runs rough. But doesn't stall
Bt Doctur
the cable not the connector .wondering if your linkage is giving you the rpms
CaptainMak
Took the throttle cable off completely. Same high idle. Will replace the IAC today and see if that helps. If not that, I'll save the aggravation and cave in for the local shop here. :facepalm:
alldodge
Suggest take it off and clean it with some carb cleaner before buying another
BTW, did you use the Merc engine rings to pull the engine or bolt the chain to another location? Also when pulling the engine did the chain rest against anything which may have been moved/bent?
CaptainMak
UPDATE*********
Went to NAPA and got a new IAC (idle air control) valve. $25 part # 3-1755.
Installed.
Motor started at about 1100 rpm for 10 seconds, then dropped to 750. Wohooo.
If it wasn't so early in the morning, I'd have a toast for all you guys that helped out. :)
CaptainMak
Been starting it all day on and off since about 9 am. Fires right up, idle at 650 stable. In FORWARD gear idle, 1100rpm. I'm sure it will be lower once in water.
