phishinout
- Mar 15, 2009
- 25
This motor has ran well.......having a problem with high idle. Recently purchased! Compression around 130 on all cylinders.
I will run it for 10 minutes or so, and any time you go to neutral it will idle at 1200 rpms and will not go down until you let it sit in neutral for 5 to 10 mins and sometimes not at all.
Also, anytime I crank it on the hose it will idle at 2000 rpms, have not ran it long enough on the hose to see if it will idle down......
Is any of this normal?? What are the first things to check w/ this type of problem?
Thanks in advance...
