mnewman949
- Jul 20, 2012
- 13
I have had an issue since I purchased my boat where it take a good amount of engine RPM (2500) to Prime Raw water pump. When I first get the boat in the water I let it idle up to temp around 160 - 180 degrees. At this time I need to run the RPM's up to get raw water circulating around my Heat Exchanger.
While I can live with this little procedure I would like the system to function as intended.
More Info:
1997 Volvo Penta 4.3
DP-SM Outdrive
New Exhaust Risers and Manifolds
No Thermostat at this time
New Raw Water Impeller
No Leaks inboard in cooling system.
More Info:
DP-SM Outdrive
