Hey Tohatsu Guru!
Can you also change the timing cam in a Nissan 25 horse 4 stroke to increase HP to a 30 horse same as you have recommended for a 9.9 to a 15?
if so do you have a part Number and do you sell them?
Many thanks,
Graham
TOHATSU GURU
Re: Hey Tohatsu Guru!
To turn the 25 into the 30 you have tho change the carb mounting gasket. If you have a hand tiller engine you also have to remove the throttle block in the rubber throttle grip.
Thanks Elvin,
Do I just use the 30 horse carb gasket to replace the current one?
I appreciate the help,
Graham
