Hey, Tater!
Frank Acampora
I tried your hint for removing flywheel nuts today. Worked like a charm. Probably the best hint I have seen here.
UncleBuck81
Re: Hey, Tater!
Awesome! That is a good trick and I will try it out tom, have to change a stator. Thanks to Tater and Frank for reposting so I saw it.
GA_Boater
Re: Hey, Tater!
I bet that would work on my Merc too. Locking down the flywheel to get the nut is a bear. Hope I remember the next time it has to come off. Thanks guys.
tater76
Re: Hey, Tater!
Thanks or the Kudos fellas :) Hope it saves some knuckles ;)
Frank Acampora
Re: Hey, Tater!
I don't usually do this but I really think this deserves to be bumped. Tater used a socket. I happened to have a chunk of aluminum just the right size. Really though anything that fits in the gap between the land and flywheel teeth would probably do well. And remember: It also works for torqueing the nut to specs.
Dang! you would think Chrysler purposely put that land there and then never mentioned it in the manual.
tater76
Re: Hey, Tater!
Here are the pics again for your enjoyment ;)Haileyebay 001.jpgHaileyebay 002.jpg
